Denford Triac Spindle Issue
Having had some issues with connectivity, I’ve had some success… yay!
I can now connect to and drive the axis from the laptop.
This includes by home and jog functions.
I can operate coolant pump etc, so machine and laptop are talking.
I’m struggling with the spindle though…
When activated, I can hear a solenoid/switch flick inside the control box, but nothing happens at the machine…
Any thoughts on where to start investigations??
Thank you
(Also posted on the Denford forum)
Re: Denford Triac Spindle Issue
I see Martin has replied on the Denford forum, and it could just be a fuse.
IIRC the relay controls power to the spindle drive, so first is to check if the drive lights up at all. If not, it could be a fuse, but then there is often a reason the fuse has blown, and is the reason why I converted mine to a servo spindle.
