Plasma torch doesn't work after connecting Proma THC 150
		God bless You,
After I had set up Mach3 to use Proma THC 150, plasma torch has stopped cutting material. Not even turning torch on manually by clicking F5 works. Previously it worked. By the way, I use AXBB-E to control plasma cutter.
What should I change in Mach3 configuration to fix problem?
Sincerely,
JBL_LG
		Re: Plasma torch doesn't work after connecting Proma THC 150
		God bless You,
I have found solution. Relay for torch hasn't been working, so it gets replaced with another one. Torch is working now.
Sincerely,
JBL_LG
