CNC Router machine not cutting deep enough Mach 3
Hi All,
I am a retired and have recently purchased a router CNC machine to use as my hobby.
I am new to this forum and also new to the CNC machine, so I'm hoping someone can help with my first problem.
The problem is that the router is not cutting deep enough, Regardless which font I use.
On most fonts it is barely scratching the surface of the wood that I am trying to engrave.
I am using Vectric Aspire 10.5 and Mach 3.
The G-Code is written in metric and for quickness, I have only placed a couple of numbers in the code to try.
I have also just fitted a touch plate to confirm the correct height etc.
When I operate the machine using the Touch plate it goes through the correct motions, but when I click the go to zero button it does not go to the wood height and stops a few mm higher.
Appreciate anyone's input to help solving this problem , Cheers, Yarlo.
