Annoying issue with my cnc router
		Good Day All,
Sorry If this is in thr wrong section.
I have a home built CNC router running mach 3. Was built in 2011.
Long story short.... Left machine running a finishing pass on some vacuum forming molds came back once finished and the spindle was sitting very randomly spinning in a none natrul way. https://youtube.com/shorts/OUIfTT_EAKI
Parts I have changed thus far....
A new pmdx 126 and 107 board have been fitted.
If any one can shed any light onto this i will be greatful as you all know, Its an expesive table if its not cutting.
Thank you in advance
regards Tom
		Re: Annoying issue with my cnc router
		Have you checked for a broken connection at the spindle or somewhere along the cable where it gets a lot of flex
		If i had enabled the spindle and it was doing that i would understand wiring but thats only just enabling Mach 3 before its referenced,
		What actually switches on/tells the VFD to power the spindle?
BOB output? via a relay? MODbus? ??
		I have a PMDX 126 (BOB) then a PMDX 107 options card that controls the VFD
