Colchester Student 1800 Square Head Lathe - HELP !
		:?:  :?: colchester student 1800 squarehead lathe :!:  :!:
Help Help Help
I have had the(luck) i am not so sure now, to aquire the above lathe for only £200.00.
Unfortunatly person or persons had robbed it for spares, :cry: somthing i did not know when i bought it :x ......albeit from a scrap dealer, still what is left is in dam fine nick, and well worth renovating.
one of the items taken are the change gears, now i am quite capable of cutting these gears if i knew what the original blank diameters were.  is there any one out there who could either provide this information or could measure the root dimention of there change gears, so i can make a start at cutting gears :|
Info/at/foundry-foparsdotcodotuk written in this form to reduce spammers
Roger
		Re: Colchester Student 1800 Square Head Lathe - HELP !
		Hiya, i have moved your post to these forums, you should get a better response this way !
		Thanks for moving post, :D
Roger
		Sorry, dont have a student, but from memory some colchesters have the gear data on the inside cover.
i will check out the 'odd job' lathe and see if i can find any data for you
