13 Attachment(s)
CNC CSLAB,hybrid stepper plus more
for sale as a job lot dont really want to split as it would be pick up only
6-axis Motion Controller. CSMIO/IP-S board (step/dir), Ethernet with threading module (from memory i could not get a motor to work from channel 0)
4 nema23 hybrid stepper motors with a spare board
RS dinrail moutable PSU plus smaller PSU
Huanyang spindle and control
Case it is a Hager TPN ip rated case, perfect for an install cabinet
A few other bits included
Pilz unit, water pump and pipe for spindle, some wiring drag chain, wire cover, aviation connectors
pictures attached
any questions please ask I expect a few as the description is quite brief will update as I go
its pretty much everything needed for a install just add frame
Price £700 ono
Location Telford Shropshire
Re: CNC CSLAB,hybrid stepper plus more
If it's pick up only you might want to mention where it is to be picked up from? :beer:
Robin
yeah that's very good point will edit
Not in the market, sorry, but reading through, my only question was Spindle specs? kW and collet size would be helpful :)
Did you get the details for the motors?
Did you find the details? Cheers
ian8415
have replied to the PM
small ones are 3amp large is 4 amp
