ATC Adapters (Mechatron)
Hi all
I know the likely response to this post (assuming there will be some), is that adapters aren't as good as the real thing. I agree!
But how bad or good are they?
I would also like to know how much work + added costs go into performing this conversion (although I suspect that's a thread for a different part of the forum?).
I currently run a:
1x Huanyang 400HZ ER20 80mm 2.2kw water cooled spindle
1x Huanyang HY series VFD spindle drive (although I don't expect an adapter to interfere with that since it runs off the initial spindle)
I assume there will need to be some software situation which tells the spindle to go to the tool change area etc...
I use UCCNC software. (it's a JazzCNC machine).
Any help; much appreciated.
Kind Regards
