Spindle and VFD help
Hi everyone, been a while since I’ve been on here, hope you guys are all good 👍🏼
I’m dealing with an issue that I’m hoping you guys can help me out with, and that is, my VFD setting have all changed/reset their self for what ever reason. I did have a power surge last week so it could be that, protection has been put in place now as it also blew one of my drives.
I’m looking for help on setting up the VFD setting again, what to input as I’ve no idea 😔 manufacturer wouldn’t help either
My setup is as follows
* VFD
Sunfar E380 3 phase,
TYPE - E380-4T0055G/0075P
SOURCE - 3PH 380V 50/60Hz
OUTPUT - 8.6KVA 13A/11KVA 17A
SERIAL NO - A00 6AHXPJFAJ0170
* Spindle
Water cooled 4.5kw
3 phase
24000 rpm
300-400Hz
VFD Manual https://salecnc.com/manuals/Inverter...s%20Manual.pdf
As always the help would be very much appreciated
Re: Spindle and VFD help
Hey D man
Everything you need is on the parameter list page 29 of the manual
not sure what control board you have. if you are just trying to communicate with your spindle then
F0.1 select what power is the output normally for a spindle commination is 0v-10 so set that to 5 but double check
F0.2 what the max frequency? 400 is what i see for most motors so double check
F0.4 select how you want to comminate with your board. right now its prob just the panel. so set this to 1
Thanks mate, I managed to get it going before your reply, for for some reason it seems to stop when heavy cutting so having to do light cuts.
I’m using the CSMIO IP/S at the moment but, if I can just get it running properly manually for now I’ll be happy.
