I need something routing out ~76cm*150cm and my machine can't do it
Plywood with a 0.9mm aluminium sheet both the same pattern the aluminium sheet is the cover to hide the ply and will be glued on eventually, maybe it could be glued and screwed before routing and done together in 1 go
Would rather pay a member than a machine shop
It's relatively simple everything is 2d routing
