I have Charmilles Robofil 4020 SI & Robofil 4020-1 machine. Please support to install USP port for uploading program it. Currently I'm using a floppy disk for uploading program to machine which is comes with machine.
Thanks.
Thanks.
What are you hoping for?
I need to install USB port for upload program. At the moment I'm using Floppy disk for upload program.
Well, there appears to be little information online as to what the control software is or what computer it runs on so it will be very hard to advise you. Suggest you contact the manufacturer to find out what might be possible.
If it's just to make uploading easier, a USB floppy disk emulator might be an option, such as - https://www.amazon.co.uk/Emulator-Si...dp/B08G8J48YR/
That was just the first search result I found, but there are many options so I'd suggest doing a bit research on them.
