8 Attachment(s)
PocketNC v1 | 5 Axis CNC + Tools + Accessories
Hi everyone,
I am looking for a good home for my PocketNC v1 due to relocation.
Coming with 6 tool holders, tools, screen, keyboard, mouse and storage cube.
Precise and capable, it really is great tool.
Key Technical Specifications:
Machining Envelope: Ø3.0″ (76.2 mm) x 3.5″ (88.9 mm) cylindrical workspace.
Material Compatibility: Aluminium, plastics, and wood (light machining of steel possible).
Axis Configuration: 5-axis simultaneous control (XYZ linear axes + A/B rotational axes).
Spindle Speed: Up to 10,000 RPM, with a belt-driven spindle.
Accuracy: Repeatability of ±0.002″ (±50 µm), sufficient for precision prototypes.
Tooling: ER11 collet system supports tools up to 1/8″ shank diameter.
Controller: Linux CNC, compatible with Fusion360 and other CAM software.
Power Requirements: Standard 110/220V AC with a small power footprint (~200W).
Experience with CNC and fusion360 is recommended.
Note :
- Few small marks on the top surface of the spindle bearing. No effect on performance of the bearing.
- Only ever had an issue with the spindle’s encoder. Simply needed to be glued back in place.
Prioritizing local pickup and direct bank transfer for this machine but open to discussion about alternative payment method and shipping within the Uk (£135 insured for £3500).
