19 Attachment(s)
Rails, ball screws, complete working control box, spindle & VFD, steppers, end mills
Hello,
I'm selling parts of my CNC which I built in 2015 with several posts on this forum.
It worked like a charm but took too much room so I dismantled it in 2017.
Main parts:
- 2 x rail SBR20 1300mm
- 2 x rail SBR20 2000mm
- 2 x rail SBR20 600mm
- 1 x ball screw SFU1605 1300mm
- 1 x ball screw SFU2005 2000mm
- 1 x ball screw SFU2005 350mm
- 12 x SBR20UU supports
- 4 x Nema 23 450 oz-inch pre wired for my control box
- 1 x Huanyung FVD PD002 220V 2.2kw spindle with VFD
- water pump + tubing that goes with it
Control box:
- architecture and discussions around it here: https://www.mycncuk.com/threads/9333...-Diagram-check
- pictures I posted a couple years ago: https://www.mycncuk.com/threads/9333...2813#post82813
- it contains a printed diagram of fuses (latest revision)
- it contains a printed wiring diagram (latest revision)
- wiring diagram, but I posted it here a few years ago: https://www.mycncuk.com/threads/9333...5861#post75861 (not sure it's the latest revision)
- QElectrotech wiring diagram (not sure it's the latest revision): Attachment 32552
The electronics inside:
- 5 axis breakout board compatible with Mach 3
- 4 x stepper driver AM882
- 70V 10A linear power supply
- 24V power supply
- 5V power supply
- homing touch probe
- E-Stop
- master switch
- fans switch
- limit switch override switch
- reset
- limit switches buzzer
- fuses for all power supplies, VFD and water pump
- plugs for all axes, water pump, limit switches, computer...
Accessories:
- a bunch of carbide end mills (2-6mm, 6mm x 32mmn, shaving, ball, carving...)
- a bunch of switches, mechanical limit switches, proximity limit switches, connectors, relays, fuse housings
- a bunch of meters of wiring
- printer port cable for the 5 axis breakout board
- a few extra stepper motor couplers
Price: make offer
Shipping: I honestly don't know how I could pack all this to send it to you, I'd have to research a bit. That said, if you're in the UK, you might just come pick it up as I'm in Belgium. Must be discussed.
I'm available via WhatsApp at +32488272001
A bunch of pictures attached.
Wishing you a very good day !
Re: Rails, ball screws, complete working control box, spindle & VFD, steppers, end mi
Everything has been sold. I don't know how to delete this post.
