8 Attachment(s)
Vertical CNC Machine - Scotland - Converted to steppers - controller required. £1499
Bridgeport Interact II Vertical CNC Machine - Converted to modern NEMA 34 stepper motors
£1499 – Glasgow G209BT INC VAT!
A bargin for a potentially very capable machine that could tackle many various industrial and hobby tasks.
Bridgeport Interact II Vertical CNC Machine for sale.
A solid, heavy-duty machine with plenty of potential, now set up to run from steppers
The spindle is 3 phase but with an inverter it could run from a single-phase supply no problem...
Perfect for someone looking for a capable heavy duty vertical mill with a robust spindle and upgraded motor setup.
It also have a massive and solid bed with ample t slots.
A large coolant tray is also included but not shown in the pictures.
Key Features
Bridgeport Interact II vertical CNC machine
Can be used as Single-phase setup (with inverter - not included)
Upgraded with NEMA 34 stepper motors
Continuously variable spindle transmission
Spindle speed range: 50 RPM to 3000 RPM
Heavy-duty spindle with heavy duty bearings
2 HP spindle motor
Encoder upgrade possible (motor shafts are long enough)
The spindle is a very heavy-duty unit with a strong bearing setup and continuously variable transmission, giving a useful speed range from 50 RPM up to 3000 RPM — suitable for a wide range of machining work.
The spindle motor is 2 HP single phase, and can be run using an inverter drive for even more spindle speed control and enable single phase operation.
Condition
Sold as seen
Good project / workshop machine
Strong mechanical base
Ready for final controller/inverter setup depending on your preferred configuration
Collection / Delivery
Viewing welcome at: G209BT
Please note:
This is a very heavy machine
Just about movable by pallet truck
Machine height is approx. 2220mm - check height of your doorways
Weight estimate 2te maybe a little more.
Delivery options:
Local delivery available for £200
Delivery is by trailer only
No offloading included
I can also arrange local hiab delivery including lifting to the ground.
Contact me for a quote for longer-distance delivery
VAT included in price.
email [email protected] if interested.
