Anyone have a UK source for open ended 10mm T5 Polyurethane belt
I have a need for around 7 meters of open ended (i.e. off the roll) 10mm wide T5 Polyurethane belt. I have found a US source at a sensible price, see here http://shop.polybelt.com/10T5-Open-E...-B10T5-MPS.htm but unfortunately no shipping to the UK. Does anyone have a sensibly priced UK source they have used ?
Cheers, Cam.
		Re: Anyone have a UK source for open ended 10mm T5 Polyurethane belt
		hi cam
             have  looked  for  open  ended  timing  belt in  uk  before  , and could  only  find    this, its  not  t5  http://www.motionco.co.uk/timing-bel...-25_38_49.html
		cam
        another  option  is here  not  open  ended  belt  but  couldnt  you  get  a  long  belt  and  cut  it  http://www.bearingboys.co.uk/Timing_Belts-1039-c
		Might be worth being a bit careful. This was on that web site.
Codan Rubber Limited – In Administration
Thursday 18th February 2010
The affairs, business and property of the company are being managed by the Joint Administrators who act as agent for the company without personal liability
G P Bushby and M Wild are licensed to act as insolvency practitioners in the UK by the Institute of Chartered Accountants in England and Wales (IP numbers 8736 and 9300 respectively)
		Thanks for the links, unfortunately I can't cut a belt because I can't find one long enough. I need an axis travel of 1 meter, therefore I need a belt just over 2 meters. The http://www.roulunds.co.uk/ web site looks the best, but the price is still much higher than the US one. I think I may contact the US guys and see if they are prepared to ship to the UK. I will let you know how it goes.
Cam.
		Mel
Just to clarify was it MOTIONCO that is winding up? as there it where i am getting my belt from for my build.
TNX
		I think it was http://www.roulunds.co.uk/ they have Codan plastered all over their web site.
		Sorry. I should have made it clear. On the Roulunds web site it shows the history and they are Codan one and the same. I cut and pasted direct from http://www.roulunds.co.uk/ .
