clarke cmd10 milling machine - £200
milling machine is in really good condition.
http://i560.photobucket.com/albums/s...l/PICT0027.jpg
http://i560.photobucket.com/albums/s...l/PICT0024.jpg
http://i560.photobucket.com/albums/s...l/PICT0023.jpg
http://i560.photobucket.com/albums/s...l/PICT0022.jpg
http://i560.photobucket.com/albums/s...l/PICT0021.jpg
A compact milling/drilling machine.
150W, 230v motor
Variable speed 1000 - 2000rpm (no load)
Sturdy cast iron head, base and column with a ground finish.
MT2 spindle taper with 10mm chuck capacity and throat size of 140mm
Mill capacities - Face 20mm, End 10mm
T slot 8mm
buyers needs to collect, dumbarton, scotland
Re: clarke cmd10 milling machine - £200
Thanks for posting the pictures, I had always thought that the cmd10 was almost the same as a sieg X1 but the base on yours is way different.
Peter
ptjw7uk
Peter
They come from the same factory but they spec them with a fixed column, IMHO a better feature as they are stiffer but many want the tilt variation even if they never use it. :rolleyes:
I would like to change mine to the fixed head type as I prefer to tilt the job rather than the mill, just another for the wish list, gets longer than days in the week!
Peter
