Re: Problem with calibration
Well further checking the lead screw seems to have developed a bit of a bend to it. Will check the bearing screw to be sure that is secure and not causing a problem on the free end. If it is the lead screw, any suggestions on a Marchant Dice 3 axis router for fixing the problem as this is really a bummer as need to get some cutting done yesterday for a client.
Michael.
Well the cap screw was loose and decided to re-true the whole system. Which now has me able to run at 550mm/min on the long axis with an acceleration of 2.5 which at 1/8 stepping gives me pretty good accuracy. As it is going to have to grind a bit off the end of the x axis or double check it's cap screw as it is now binding against the stepper post. Man am I looking forward to the oldham clamps getting here.
Still would like in put as to why not able to hit anything above 550 without dropping steps and locking up with over rev's. Z is doing fine at 450mm/min which gives a really nice smooth movement up and down and more than enough control in steps. So figured a good bit of it out myself. Still would like to get it up to 850 or 1000mm/min movement only to allow a bit faster cutting speed and quicker movement between cutting points.
Michael
Micheal,
What screw dia/pitch on X?
Irving,
Let me be sure I understand. You want the thread pitch (angle of the face of the thread) for the short axis on my machine? I have gotten the calibration under control though and down to .05mm repeatable tolerances. Which is good enough for now. I cut off a bit of the X axis as it was butting against the axle of the nema motor when mounted in properly. So that is fixed and is now running very well.
Michael
no, I was interested in the size of the leadscrew dia, length, pitch (e.g. 16mm, 800mm long, 5mm pitch) so to see if you were getting any effects from the screw inertia exceeding you motor capability at the acceleration you had programmed. Sounds like you were hitting some issues due to excessive endloading due to the screw being too long and this translated to a binding effect which may have been limiting your top speed by preventing your rig accelerating without loosing steps.
