Ball screw fixed end DIY support ideas needed.
		I'm wondering if exist a way to build in a simple way the equivalent of a flanged mounting block for the fixed end of a ball screw.
Unfortunately cheap commercial models are for 10mm shaft, ergo 7200 ball bearings, while a need a support with 12mm bore diameter, so 7201 ball bearings.
These items are quite expensive for low budget projects and i'm considering to try to build a couple for X and Z axis of my DIY XYZ pantograph.
Of course i do not pretend same strenght and precision of metal ones, but something that would be OK for a wood machining CNC device.
The first problem is :
i do not own a lathe ...
but maybe with a quality forstner bit, some delrin slices, a couple of 7201 bearings and a collar  ....
Has someone managed to get something similar to work good ?
Marco.
		Re: Ball screw fixed end DIY support ideas needed.
		Marco you could always go with a bronze bush (oilite bearing) and a couple of thrust bearings at each end as a cheap option?
		It could be an idea, but i still have to find a way to build a main assy that carry all parts.
Do you have a photo of a similar implementation ?
		ccmarco
              i had the  same  prob  as you , i had  a 12mm diameter   trapezioid    screw    ,  so  i turned  the  screw  down  to  8mm  using a grinder and  a  drill  as  a lathe ,  threaded  the  end  for  a locknut  ,  used a 100mm x 100mm x  10mm   plastic   shim   with  a  22mm   hole  drilled  in  it( to take  a  skate bearing)  as  a bearing  block.   so  it  went  ,  thrust  washer -  bearing  block  (with skate  bearing  )  - thrust washer  -  locknut   , tighten  locknut   to preload    assembly  ,  solid  and  cheap    i  have  no  lateral  movement  in  screw .....    phew!!!  maybe  a  pic  would  have  been  better
		Hi John,
yes, a pic would be good.
It's all clear thrust washers aside.
Unfortunately the screwballs machining requires a good lathe and proper skills, any other attempt will fail unsafely.
Here in Italy, lathes are quite expensive, anyway i'm thinking to buy a little one at least to work small parts.
Could you take a shot of your assembly ?
Thanks,
Marco.
		Marco surely there must be someone local to you who can do the screws.
Phil
		Hi Phil,
sure that, i already have a deal with a professional lathe worker for ballscrews machining and ball bearings flange build, but it would be more funny to make my own screw supports, at least.
About ballscrews, i have space only for a small lathe and as far as i know, hardened steel is too much for similar tools.
Or i'm wrong ?
Marco.
		Marco i have never tried turning ball screws, i have a cylindrical grinder and did mine on that.
But a small lathe would struggle with hardened screws
By all means make whatever you are capable of making, but it is false economy to make something that you cannot make accurately.
Phil
		Phil,
i'm not looking for a way to machine ballscrew's ends by myself with improvised methods.
Instead, my purpose, for non critical applications, is to build, only, ball bearings support flanges.
Of course, for professional high quality CNC machine making, this does not make sense.
Marco.
