Hypertherm Duramax Torches to upgrade Powermax 1000 & Powermax 1250
		DuramaxHRT
HandheldRetrofitTorch
DuramaxMRT
MechanizedRetrofitTorch
DuramaxTM HRT and MRT Retrofit Torches
 Upgrade torches for Powermax1000â and Powermax1250â systems
Summary:
Hypertherm is pleased to announce the availability of two new upgrade torches for Powermax1000 and Powermax1250 systems. Duramax HRT and MRT torches use the same superior,  torch and consumable technologies as the new Powermax65 and Powermax85 torches.
Benefits:
Ordering
Information:
Duramax torches offer many advantages over older torch technologies
More durable:  Proprietary, fiber-reinforced torch handle is 5 times more impact resistant and 20% more heat resistant to withstand the toughest metal-cutting applications.*
More reliable:  Patent-pending Spring StartTM technology eliminates moving parts within the torch head for more reliable arc-starting.*
More life:  Conical FlowTM  nozzle and spring electrode deliver up to 55% more consumable life for up to a 30% reduction in consumable costs.*
Plug-and-play upgrade:  Duramax RT torches use the same Easy Torch Removal (ETR) connection as standard T60 and T80 torches which makes retrofitting to a new Duramax torch simple.
Promotes consumable consolidation: Use one torch for both Powermax1000 and Powermax1250 systems and the same consumables as the new Powermax65 and Powermax85 systems.
Competitively priced: The new Duramax HRT and MRT torches are priced in line with standard Powermax1000 (T60/T60M) replacement torches.
*When compared with standard T60 and T80 torches/consumables for Powermax1000 and Powermax1250
Torch assemblies
Duramax HRT hand torch assembly with 7.5 m leads**
Duramax HRT hand torch assembly with  15 leads**
Duramax MRT machine torch assembly with 7.5 m leads**
Duramax MRT machine torch assembly with 15 m leads**
