Easy way to generate dxf files
I was hoping to update the cam software for my Sei 810 personnel router but I don't seem to be able to find a post processor for it, which seems to rule out cut2d bobcam ect.
Fortunately I do seem to have made some progress with Sei's cam program although it does run in dos which isn't ideal. What I could do with is a very easy program for generating simple 2d dxf files which will enable me to have a play with the machine and deciede whether to put up with the ancient cam program or update the electronics on the machine.
Thanks,
Paul
Re: Easy way to generate dxf files
Paul,
First off the good news, you don't have to buy a program to do what you want.
there are loads of free ones out there that will do all you need.
One good free program is Draftsight, do a Google, downside is it takes a bit of learing but there are loads of video's on Youtube.
Possible the easiest is one called Deltacad, http://www.deltacad.com
$40 to buy but you get 30 days free and if you reinstall it you get another 30 days.
Give this one a try first, it is easy to use.
Thanks Bill,
I will give it a try
BillTodd
Thanks, John . I will give both your suggestion and Bills a go.
Thanks again,
Paul
