can't cut straight or even drill straight, so need help
I'm in the process of trying to build the cnc off this website, the "book machine"
http://buildyourcnc.com/Documents/CNC%20Kit%201-1.pdf
This is the parts required though some can only be cut after the bulk of the build has been done. I was trying to cut this from 18mm mdf:redface: but am having no luck. Would someone be willing to cut some of these parts on their machine for a price of course
Z axis bearing supports
Y axis linear bearing supports
Gantry sides
Re: can't cut straight or even drill straight, so need help
Yep I'll cut them for ya but when do you want them for.?
When can you do then, all the holes if you could just drill them as a pilot hole as i'm using different size bearings and bolts etc. Would you be able to do the 6 motor mounts as well. Could you pm me with a idea of price, i know postage would be costly because of weight
