Machining, fabrication and engineering services available...just drop me a line!
Hi All
Thought I'd put a thread on here offering the services of my company to anyone needing it. I own a small engineering company covering a wide range of processes and industries, we have the following equipment ~
Colchester Tornado T8MSY - Twin spindle 6 axis turning centre with live tooling and y axis & bar feed - 1 off
Colchester Tornado T8M - Single spindle 3 axis turning centre with live tooling and bar feed - 1 off
Colchester Tornado T6M - Single spindle 3 axis turning centre with live tooling and bar feed - 1 off
Colchester Multiturn 2000 - 2 axis CNC centre lathe - 1 off
Excell D660 - Manual centre lathe, 660mm swing x 2m centres - 1 off
Herbert 4 Capstan lathe - 1 off
Herbert 2D Capstan lathe with bar feed - 1 off
Haas Mini Mill CNC Machining Centre - 1 off
Hurco VM1 CNC Machining Centre with 4th axis - 1 off
Hurco VM10 CNC Machining Centre with 4th axis - 1 off
Ajax AJT1 Turret mill - 1 off
Centurion CU5 Ram Mill (Huron copy) - 1 off
Kearns S type horizontal tool room borer - 1 off
Elliot 8 x 18 surface grinder - 1 off
Richmond 4mt, 3ft arm Radial drill - 1 off
Bandsaw with mitre head - 1 off
Fully equiped welding bay for Mig and tig welding in steel & stainless steel
Fully equiped assembly area and hydraulic test facility
Fully enclosed and filtered dry back spray booth
We also have large stocks of steel in various grades, aluminium, stainless steel, hydraulic ram materials such as cylinder tube & piston rod.
Whilst this may seem like a obevious add for my company, honestly it's not - just thought i'd offer the facilities to anyone who needs parts making!
More details and machine capacities can be found on my website - www.hi-speceng.co.uk
Many Thanks
Darren
