Setting Bridgeport Heidenhain System …
Hello
I am a CNC Miller and I lost my jobabout 3 years ago, then I left for England and I've been here forabout 2 years
I'd like to find a job in a similarrole
I need please a help to remember allthe steps for a setting on a CNC Bridgeport 3 axses with heidenhainsystem TNC 370 or 410
- select on the controll pannel the program and read on it if we need to put a special jig on or if we need particular tool to clamp our raw piece
- clamp our jig or vice on the table and clock if necessary
- Set the datem of X, Y, Z, (once I touched with handweal a stop on the jig What do i need to type on the screen?) I remember: Manual > Zero > Enter. Is it correct?
- see on the program all the tolls we need, mount all the tools in their weldons or tapingheads, measure the tools
- put the tools in the spindle and type on the tool table the length and the radius
- in editing mode change the number of the tool in the program (if necessary) according to the position in the carosel
- put the tool in the carosel and empty the spindle, (on MDI mode > tool call > toll number of the next free pocket in the carosell)
- go on in this way for all the tools
- clamp the first raw piece in the vice
- single block > press start for every block > check the position of the first tool (check datem and length of the tool)
- full sequnce > run first tool
- do the same operation for all the tools
- when finished take out first off, do a full quality check and if it is fine start the production
May you please tell where I coulddowload a free manual for TNC 370 or 410?
any suggestion about better technicalterms will be very appreciative
Any suggetion according to how to do agood settings will be very appreciative
Re: Setting Bridgeport Heidenhain System …
I've already dowloaded a manual TNC 410 which is very good
But I need more help please!!!!!
Not sure if this will help but the g-code should be the same on the bridgeport.
http://www.cnc.info.pl//files/fanuc_...aining_588.pdf
Sorry D.C. but Heidenhain System has no G code ....
Oooops, sorry about that.
They seem to have some free elearning stuff on their site, is that any good to you for brushing up?
http://content.heidenhain.de/present.../EN/index.html
These guys also have some simulation software for use on a PC
http://www.cnctrain.com/index.html
Thank you very much D.C your links are very interesting
I was wandering if I could get a software like that Demo Software on your suggested website where you can really use it on your PC in which you can make programms, the same as a normal CNC Machine on the shop floor
I didn't know even that existed such a software like that Demo Software now I know and I want a proper software even if I have to pay for that, where could I get it? If I am able to get it I have all I need to refresh my memory... Thank you very much indeed again
D.C. this link http://content.heidenhain.de/present.../EN/index.html is very very goog Thank you very much indeed
