Does anyone have a Boxford 125Tcl chuck for sale or could tell me where or what fits.?
Think Robbin's got one of these...
It looks like that lathe takes an 80mm chuck, in which case a generic chuck should fit as they are standardised. You should be able to just measure the spindle register diameter, and hole positions then check them:
Lathe Chucks - Arc Euro Trade
They're cheaper on eBay, but the drawings there are good.
Can you get a cheaper degree off Ebay, I'll have to have a look.
Original Pratt and Burnerd are 82mm diameter, just measured.
Its under a bench, cant lift guard up.
Three cap hd screws fix to spindle close to the bore of chuck so might be very limited on what chucks will fit ie clear the scroll.
Ok cheers anyway. . . . . Ye that's what I suspected has the spindle nose has threaded holes in end but thought they must be close to Bore.
I'll see what's available and then if not then I'll try to find one with correct register and maybe drill.?
Bit of rust on mine, might not show up very well.
If i get chance i will see if i can get a piccy.
Bought it three years ago and never done a thing with it.
