2 onld controllers, 5 by 4 modular table, 4 - 4ft sliders, 2 air rams, 2 pimps, etc
hello, I do realise it IS a complete liberty having your first post as a for sale but read on please.
I just bought an enclosure, cnc / liquid gasket printer, for the desktop Isel Techno FB2 that was inside.
so I am offering all the bits that I don't require, but I do want new motors and controllers, mach3/4 and that, anyways here goes
here is what I bought, took two goes in my little estate car, Fulham London to Stafford, but at least now it is all in bits
http://img.photobucket.com/albums/v2...ps5cc8da6c.jpg
the long side are 90 by 45 = 1450mm
there are six bits
the short sides are 1080mm
there are 6 bits of this - maybe 8
the legs are 90mm by 90mm and have bolt in feet
there are 4 complete blue panels, for all 4 sides
the buttons on the front could be for auto stop
http://img.photobucket.com/albums/v2...psa7770e3d.jpg
if you left it as it is, max width is 1080 plu 90 plus 90 = 1260mm, 4ftand a smidgers
the long then is 1450 plus 90 - leaving the tall legs = 1540mm, 1525 is 5ft
theer are 2 bits of 90 by 45 to make the y axis with, i think another few lengths to make a shelf on the tall legs, and the z axis
there are 2 3/4'' 19mm solid alloy plates to make the gantry ends, there are another two bits of 15mm or 19mm to make the z axis
there are 4 four foot flat sliders with bosch bearings, enough to then do the y axis and loads to make a very rigid z axis.
these are fitted to 4 bits of 60 by 45mm -
THERE ARE ALSO A PAIR OF IAR RAMS AND 2 PUMPS AND LOTS OF PNEUMATIC CONTROLLING STUFF - I DON'T KNOW WHAT IT DOES THOUGH.
http://img.photobucket.com/albums/v2...psd8e1d08b.jpg
there are two of those alloy thick plates with a nice hole in the centre for you to cut a pair of welly boots from, and have the nice radius
also there is stack and stacks of 45mm box, lots of nuts and bolts
all the wireing is there to the controllers about 1998 from what I can see, I can take a pic.
there are 2 old wee amc 3 axis controllers, , two hand held doofers, all the wireing and connectors
all used
IT IS ALL APART, YOU CAN GET IT IN AN ESTATE CAR
I AM WILLING TO POST EVERYTHING - BAR THE BLUE SIDES AT COST.
NOW THE BEST BIT i NEED
http://www.cnc4you.co.uk/index.php?r...product_id=217
ALSO NEED A SPINDLE AND MOUNT
AND SOME MACH3 - OR 4
OH AND A USB/lan BOB
SO HAPPY TO HAVE A SWAPSIES.
THANKS
Re: 2 onld controllers, 5 by 4 modular table, 4 - 4ft sliders, 2 air rams, 2 pimps, e
do you have the complete router? if so would you be interested in a swap for an isel router with gallad software ??
john 07817 200279
its all gone, I am keeping the fb2 as its now got new 76mm 3.1 motors and new usb bob and drives and mach 3 and sheetcam, and a new custom mounted makita 700 watt motor trimmer router motor.
and its lush.
i am interested in your isel if its an fb2.
