Re: Method for holding Stock
Could you not just machine a couple of dowel holes through the part into the table before you cut it, then flip it and dowel it again?
That is one option - I could also use a set of right angled sections but the issue is that the item is round and you ideally need to have it not rotate either.
Surely if its a gear the central hole and/or boss plus an offset dowel hole would both register and locate it.
Or perhaps cut the back side first and leave a spur with dowel hole which is cut off on the front side.
