Mucky Mikes Marvelously Magnificent Machine Manufacture.
OK folks here we go............
1 No. Rockcliffe Flying gantry CNC.
I have cut most of the parts out of 19mm MDF
The gantry sides are cut from 7/8" ply (simply because I had some)
The base is also 7/8" ply
I have purchased screws and bolts, 22mm bearings, aly angle etc.
Bits and pieces. All put together with gravity at the moment for an overall effect of whats to come.
Base size is 36" x 48"
http://i128.photobucket.com/albums/p...C/P4040133.jpg
http://i128.photobucket.com/albums/p...C/P4040134.jpg
http://i128.photobucket.com/albums/p...C/P4040135.jpg
Aly angle cut to length, drilled and threaded ready for bearings.
http://i128.photobucket.com/albums/p...C/P4040136.jpg
Bearings fitted. I decided it was easier to notch the MDF rather than trimming the screws shorter.
http://i128.photobucket.com/albums/p...C/P4040137.jpg
http://i128.photobucket.com/albums/p...C/P4040138.jpg
Dry fitting run before screwing angle to MDF.
http://i128.photobucket.com/albums/p...C/P4040139.jpg
All screwed up........just like me!
Before anyone spots it, I haven't routed the channels yet, I am waiting for the stainless 3/8" bar to arrive.
http://i128.photobucket.com/albums/p...C/P4040140.jpg
http://i128.photobucket.com/albums/p...C/P4040141.jpg
Apologies for the fuzzy pic.
You will notice that I have used countersunk screws, the logic behind this is that the taper will hold the bearing
in a constant position to avoid any play between screw and bearing.
http://i128.photobucket.com/albums/p...C/P4040142.jpg
Re: Mucky Mikes Marvelously Magnificent Machine Manufacture.
looking good so far, did that Stainless Bar turn up yet or what ?
Lee Roberts
Stainless bar all cut to length ready.
Lee I will probably be getting some delrin nuts of you soon!:beer:
Ok np, let me know via a PM or email and i can send them to you. What size/type of leadscrew was you going to use on your cnc machine?
