Plastics for machining?
		Hi Guys,
I have a part I want to make, which has 3D machining on the outside surfaces, but has a 45mm deep pocket on the inside (it doesn't go all the way through, so can't double side the machining).
I'm thinking to myself that I'm not going to be able to machine the deep pocket using aluminium (on my CNC router at least), and whilst I could probably do it on my lathe/mill, I also have the option of making the part in some kind of plastic.
So question is, what "high strength" plastics are out there that machine well? By high strength I mean resistance to shock and bending forces causing fracturing e.g. ABS.
Of course I could go and get a 3D printer maybe, but CNC funds are a little short atm.
Chris
