Strengthing a steel gantry.
What do you guys think about welding in some internal struts inside a steel grantry to help stiffen it up. This would be done before epoxy leveling to account for the heat distortion from welding. I was thinking you could drill holes on the corners of the box section to allow you to pass steel rods though the box section and then weld in some 10mm rods into the holes so the rods are creating a truss structure inside the box section?
Re: Strengthing a steel gantry.
The vast majority of a beams stiffness comes from it's outside so adding material inside wouldn't make much difference unless you were going to tension the struts which I would think would be bad for stability. It might help resonance but gluing a lump of wood inside would probably make more difference for the weight. Filling with an epoxy granite mix would be better if the steppers can take the extra weight. Or maybe epoxy granite poured around a wooden core. Or maybe just thicker steel :-)
FatFreddie
Epoxy's Too expensive and messy.! . . . Can't beat Kiln dried Sand for dampening resonance, cheap as chips and removable if done correctly.
Yes the stiffness does come from the outer surfaces, but by joining them together with diagonal or X-shaped bracing you would be passing the loads between different parts of the outer surfaces. This would be stiffer, especially torsionally.
Ideally you want to place the diagonals at 45degrees to the long axis, not 90degrees, but this is difficult in practice.
You could also make baffle plates to do the same thing (say 6mm thick), slightly smaller than the inner dimensions of the box section, with the corners chamfered to miss the rounded inner edge, then drop these in at intervals and secure around the edges with chemical metal.
The section needs to be reasonably large to enable this 'key-hole surgery' but I think with some long rods it could be done.
If you do this with the gantry on it's end with the lowest/first plate attached, you could then back-fill with sand up to a point, then drop in the next baffle and secure. Repeat until full.
Significant stiffness increase, extra damping, and no welding distortion.
