Selling due to moving to Oz
Its with much regret I'm going to have to sell my upright machine. I would take it with me if i could.
It's currently an unfinished project and has taken a couple of years to get to this point but now there's a chance I might be moving down under. The rust on the frame is just on the surface as its not yet been painted but I may get round to that. Mechanically its solid but will need improvements on the bed. Electrically its uses a 24v safety circuit to control the 70v PSU. The axis limit switches are to be linked to the 24v system to shut it down in the worse came to the worse. Home switches on all axis would need to go to the breakout board to square off the machine.
Build log is here...
http://www.mycncuk.com/threads/5127-...little-project!
100x100x4 box section uprights
60x60x5 frame
60x60x5 Bed has in incline of 85 degrees to aid chip clearance
X-axis
25mm supported round rail all round
2510 ballscrews with rotating ball nuts driven by 4nm steppers
25mm Ali bearing supports
60x60x5 box sections with 20mm ali tooling plate joining the 2 X axis
Y-axis
1610 ballscrew belt driven by 4nm steppers
Running on X axis plate and box section
Z-axis
1605 ballscrew belt driven by 4nm steppers
3kw Watercooled spindle
PSU
70v unregulated
24v regulated
5v regulated
5 x MA860H stepper drivers
Working area of approx 1000x1000x300mm
I'm looking for sensible offers in the region on £2500 as it currently stands
Rob
Re: Selling due to moving to Oz
May break if there's enough interest in parts
r0bsk1
Any chance of a picture of the whole machine?
All I could see skimming the last few pages of that build thread was close-ups of random bits of it...
Would also be helpful to know your rough location.
scroll over the flag next to his name.edited that's no help.
Thanks. That says 'Ponte Carlo, UK' but Google Maps puts that in the Czech Republic.
Im in Pontefract, West Yorkshire.
If you read through the thread you'd see they weren't random closeups. I try and get a pic of the whole thing tonight.
2 Attachment(s)
