RFQ: Aluminium parts for my CNC router
Hello all,
After spending a long long time designing my CNC router, I feel I am now at the time to start getting some quotes for the aluminium parts I require. The design is not 100% finalised but I only anticipate very small changes here and there.
See full build thread here: http://www.mycncuk.com/threads/5549-...e-Materials%29
Essentially all parts require machining on top and bottom. I will update this thread ASAP with screenshots of each part to give a better idea. I can also, of course, provide STEP files for each part.
I am looking for an "all in" cost including material.
http://www.mycncuk.com/attachment.ph...id=13596&stc=1
Part 1 - Gantry Side Plate (Left)
Quantity: 1
Material: Aluminium
Thickness: 20mm
Outside Dimensions: 255mm x 160mm
Part 2 - Gantry Side Plate (Right)
Quantity: 1
Material: Aluminium
Thickness: 20mm
Part 3 - Y Axis Bearing Mount Plates
Quantity: 2
Material: Aluminium
Thickness: 15mm
Outside Dimensions: 160mm x 60mm
Part 4 - X Axis Carriage Plate
Quantity: 1
Material: Aluminium
Thickness: 20mm
Outside Dimensions: 231mm x 130mm
Part 5 - X Axis Bearing Plate (Top)
Quantity: 1
Material: Aluminium
Thickness: 20mm
Outside Dimensions: 130mm x 100mm
Part 6 - X Axis Bearing Plate (Bottom)
Quantity: 1
Material: Aluminium
Thickness: 20mm
Outside Dimensions: 130mm x 55mm
Part 7 - Y Axis Ballnut Mount
Quantity: 1
Material: Aluminium
Thickness: 20mm
Outside Dimensions: 97.5mm x 40mm
Part 8 - NEMA Motor Mount
Quantity: 3
Material: Aluminium
Thickness: 10mm
Outside Dimensions: 95mm x 70mm
Part 9 - Motor Mount Extrusion Bracket
Quantity: 3
Material: Aluminium
Thickness: 15mm
Outside Dimensions: 40mm x 70mm
Part 10 - Spindle Z Mount
Quantity: 1
Material: Aluminium
Thickness: 20mm
Outside Dimensions: 115mm x 130mm
Any questions, please don't hesitate to ask!
Thanks,
Dave
