isel fb1 cnc router used
1 new 5 axis usb break out board digital dream
3 new nema 23 sanyo motors
3 new tb6600 2by3 drivers
1 new 36 v 10a psu
1 new 300 by 200 by 100 electronics box
new iec connector with ferrite rings
new 1..5mm 7 core wire cut to length, with metal glands in the mootor cans
ferm 500watt spindle 1/8ths bits
needs a little wireing in the controller - i.e. drill some holes for the motor cables - and wire up the drives thats all - its all tested and works, the cables have the wires for the limit switches in them - these need connecting in the box
ooh I bent the limit switch stricker on the y axis - needs replacing
stock they are 1604 ballscrews
motors are 56mm 4 wire.
£1200
steve
0 seven 74 858 204 four
its a really old table but with brand new electronics!!!!!!!!!!
i only want the money to buy servo motors and drives and control for my other machine.
http://www.multi.fi/~mbc/images/isel...with_kress.jpg
its like that, but the y axis cover is now gone.
quality isel anti back-lash nuts
precision ball screws
boshe linear bearings
its a beaut but old.
still, the elestacsa are all brand new....................
the r3eason i havn't finished it - its in the shed
i was going to make it a plasma table but now realise its not feasable
the motors and elecrtics are indoors though, gives you the optiion of doing it how you likey
also have about 30 nema 23 56mm motors £15 each
8 dual shafted nema 17 the big ones £12 each
will also have soon 8 wire nema 23's 76mm, and another complete controller 3 axis 36v with a leaftboy smooth stepo card all done - will even come with motor cans and mounts. £450 = complete controller with motors 8 wire bi-polar parrallel - when my servo shiz is finished mind
plus have another usb break out board £54
what i mean is...
the z axis is off, but has the motor and wireing all done
7 core 1234 = a+ a- b+ b- 5 and 6 are limit switches, the 7th is an earth that you rivent to the motor can and then back into the electronics box
all the motors are wired- soldered and heatshrunk, simply need fitting on
connecting to the drivers 1234
and the drives to the bob 1234
and the limit switch wires 12 12 12 to the bob
you ned to take it all off anywayt o get it in your boot.
it sis just about 'hernia' a one man lift
thank you
