Recommendation of Woodwork Shop to Hire?
Hi guys,
I need to hire a wood-working shop for a day or two. I've found one in Battersea which looks good but is quite a long way from me in Gravesend, Kent. Can anyone suggest an alternative?
The job I need to do is pretty simple; just rip some sheets of ply, add a plain rebate to each side then cross cut them. So I need a table saw and a router table / spindle moulder.
Any ideas, or do you have a workshop that is not fully utilised?
Regards,
Simon
Re: Recommendation of Woodwork Shop to Hire?
Men's Sheds are a great Aussie idea....... partly to make up for being so submissive at cricket ;)
Looks as if there are now Men's Sheds already open in Dartford and Gillingham.
1. just rip some sheets of ply.
2. add a plain rebate to each side.
3. then cross cut them.
cant you use a circ saw ? run against a straight edge.
you could use a router to add the rebate.
depends how wide the pieces are... you could cross cut them with a chop saw.
or a radial arm saw.
Thanks. It's not the tools that are the issue it's the space to work and make some mess. I used to have a table saw but sold it when I moved due to the space.
fair play, i do what i can in my garage, and what i cant outside it. ( weather permitting ) :subdued:
Bugger, I forgot to give you the weblink which is http://menssheds.org.uk/find-a-shed/
Looks like the Gravesend Shed is yet to come, but there are already Men's Sheds already open in Dartford and Gillingham.
