4 Attachment(s)
RFQ: Very Simple Machining of Two Aluminium Parts Required
I have an aluminium enclosure (See below) which requires the end plates to be machined.
Attachment 16817
Attachment 16816
Part A (Front Plate)
* I can provide this plate if it is more cost effective than to re-create it from scratch.
* All internal corners have a 1mm radius. I can increase this a little if required?
* Outer Dimensions: 212mm x 70mm
* Quantity: 1
Attachment 16814
Part B (Rear Plate)
* I cannot supply the material for this plate as it already has some cut-outs which are in the wrong place.
* Again, all internal corners have a 1mm radius.
* 3mm Aluminium.
* Colour: Anodised black would be ideal, however mill finished aluminium is fine (I can paint it at a later date).
* Outer dimensions: 177mm x 65mm
* Quantity: 1
Attachment 16815
Please drop me a message on here if interested.
Thanks,
Dave
