2 Attachment(s)
COMPLETE: RFQ: Aluminium plate 150x140x12, milled/drilled
* A QUOTE FOR THIS HAS NOW BEEN ACCEPTED *
RFQ: Aluminium plate, basic dimensions 150mm x 140mm x 12mm
16 holes machined to accomodate M5 cap bolts - not threaded, with cap sunk under surface of material.
19 additional holes drilled/machined and tapped to take a M6 bolt
You to supply material, machine, and deliver to Lancashire, UK.
(Background, this is a first attempt to mount a replacement spindle onto the Z-column on a StarMill machine... I would attempt this, except the size is rather too large to work on the StarMill as a single operation)
Mike
