Thank you very much!
SW received!
Regards
Amarillis
SW received!
Regards
Amarillis
Well, seem like I'm stucked again...
So, here is my workflow...
I work with the last EMS version available that is 1.950 at the moment...
After everything is done, I save the work using the emsx file type...
I open the file emsx with a text editor and remove the line CREATOR....
I open the file with the 1.932/1.935 version of EMS and export the work using the DXF format...
BUT, I tried to open the DXF file with FREECAD and nothing shows...
So I tried to save the file in the STL format using the 1.932 ver...
At this point a popup shows telling me to upgrade to the latest version and no STL is produced...
Since I only need to 3D print my work I really don't know what to do...
Moreover, I still do not understand where to put the EMS.DAT file since there is no APPDATA folder for the 1.932 version without an install procedure...
Any help?
Regards
I'm no expert but I think that versions later than 1.935 save the file in a format that 1.932 and 1.935 can not read. I create all my drawings in 1.932. You might have to do the same but
I am sure someone with better knowledge will be along soon to give you better advice. Regards.
Well, thank you very much for your replay!
I really appreciate it!
And, by the way, maybe your are not an EXPERT but your knowledge is way deeper than mine...
So, with that said, your replay is a perfect recap of all the operations we should do to make a DXF or STL type of files using version 1.932/35...
Thank you again, I will give it a try in the next days...
Regards
Amarillis
Morning all
I am TOTALLY new to this! Im not a CAD guy....
I imported a DWG file and spent about 10 days learning the program, and editing the DWG drawing.
Much to my dismay .. when I finally got this right and wanted to save my drawing back to a DXF / DWG file..
I found out that I now need to purchase an upgrade..
FOR ME THIS WAS A 1 TIME DEAL..... I don't manufacture or anything, was just gonna have the drawing sent to an EVA foam manufacturer to cut the sheets with a 4 axis router..
I AM NOW STUCK BETWEEN A ROCK AND HARD PLACE...
Is anyone willing to let me email you my drawing, the have you save it as a dxf or dwg for me and email back to me?
[email protected]
thanks
Malcolm
Malcolm, I feel your pain. I can try to do what you are after. I will send you my email address by PM so you can send the drawing over. Regards.
HI
thanks for the reply... please any assistance will be greatly appreciated.
my email
shopsbt at outlook dot com
thanmks
Malcolm
I have been searching for 1.932 and 1.935 for a while with no luck and really need dxf files exported. If I could get links to the dropbox files that would be very much appreciated.
ZacharyPatel at mail.com
Thanks Zach.
