LOL, take a guess what im doing right now?
http://www.sgs-engineering.com/air-compressors
Snap!
Snap!
I was going to order today for delivery tomorrow as Ill be home but didnt get the time and still undecided to what size compressor I need. I dont need much for the pneumatics on the machine but Id like something for cooling too. So looking at a 100L unit. I had a 24L Bambi before, lovely, but expensive and too small for continual air for blowing on parts / clearing swarf etc.
Ok, time for an update.
Had some setbacks with some of the electronics items, not going to discuss as such but many thanks to continued offline support from both i2i, JazzCNC and Gary @ Zappautomation.
Received my compressor today as well as the solenoid / actuator items. Got mostly working, missing 2 small 90 degree items, but its installed and wired up.
I tested the carousel motor for the first time today, spins along happily. I have no real idea yet how it knows where it is. I know there is a sensor, will try and look at that again later and there is an ability to reverse the direction of travel. Clearly it needs to 'know' which tool is currently selected.
Am hopeful that this weekend, unless I have issues or some delays on parts coming in, may be able to do the the first basic milling, with or without the tool changer working.
Dont forget to post some video at the end of that . Or to say at the start of the new journey:yahoo:
the sensor reads the position of the disc on the carousel motor
I can see the motor can be reversed too using a relay called CCR. Is this commonly used in the retrofit? I know there are macros that 'know' that getting from 8 to 6 is quicker to go back 2 steps than forward by 6.
you can always add a switch to energise the valve for the toolholder cylinder, and change the tools manually.
