Re: Proximity switch problem
Charlie are you using shielded wire for the cable back to control box and is the sheild earthed just one end inside the control box.?
Also is the machine frame earthed to same earth point.?
You have long wire runs so they will act like antenna picking up any noise so you'll need to Eliminate this really before you'll get any joy.
I would also try a differant switch you maybe have poor switch with slow components giving slow reaction times.?
What do you have debounce set to in Mach3 General Config ?
Yes it's all shielded at one end the Ali frame is directly bolted to the floor the moving part of the gantry though may not have any sort of ground unless it can travel through the Hiwincarriages. The problem seams to effect all switches. I was wondering about replacing a switch but wire it straight to the csmio ? Would it be best to disconnect the rest of them if I did that?
EddyCurrent
Zero would this be the same as the filter in the csmio plug in or have the same effect ?
