John,
Should be OK for you. Let me know if it works, or if it failed.
John,
it worked perfectly !.
This is what i did
(win10) :
1) I copied the file : ems.dat.1935.txt
(https://www.mycncuk.com/attachment.p...0&d=1649730249)
as:
C:\Users\Administrator\AppData\Roaming\eMachineSho p\ems.dat
2) I used RunAsDate (https://www.nirsoft.net/utils/run_as_date.html)
to open emachineshop as date: 30/07/2019
3) I pressed Ctrl+Alt+e
Then i could save dxf files.
Thank you VERY MUCH, Bladevane !!!!
Kind Regards,
John
John, Briliant. Thanks for letting me know. Good luck in your file transfer. I now use FreeCAD for DXF transfer, although other packages are available.
Hi.
Would it be possible for me to gain access to an old copy?
Not sure how this works but I see people previous entered an email address.
[email protected]
I still use Emachineshop ( old version). I have yet to find such a simple to use CAD programme (free or for purchase). Just wish the 3D preview would work like it used to. Camabam is good but I find Emachineshop so much easier for designing/drawing. So I use Ems for cad and cambam for cam
Mike, Should be all sorted. Let me know if there are problems and I'll resend. Regards.
Hi Bladevane!
Would you be able to add me to the drop box as well? Larsson365 AT live.se
Best regards
All sorted. Let me know if you need more. Regards.
All should be sorted. Let me know if there are issues.
