Here it is:
https://www.youtube.com/watch?v=9fyzZ7NGap8
Here it is:
I would buy a mini mill instead for that money. An used one. And fashion some pillar and stand if such big clearance is needed. Or hunt for a serious industrial one from a scrap yard. It should be more than 150-200 from there. In fact thats exactly what i did/ the mini mill with a round column/ and could not be more happier.
As mentioned it's exactly what I wanted, I know you can get them within budget but I never saw one, only those really cheap tacky looking Proxxon mills.
Big clearance isn't needed, just more than the 165mm my current one has. Bench top is ideal, floor standing is ok. 280mm clearance should be more than enough.
No floor space for a real mill, and to be honest it would be overkill for the usage it would get anyway. That said, when you have the tools, you always find something to use them for.
I need to make a decision on this sooner rather than later, the Warco drill is currently odds on.
Now its not the best time to buy such things. From experience. Only after a week or two things will start to show on fleabay. I personally bough near new BF-65 Hobbymat, and i know that could be had for the money you are willing to spend, around 500GBP. Now i only see a Clarke Metalworker CMD 1225C 240v Mill Drill Milling Machine for 800. Some patience and you will find the one
If you're in a rush and a one off, I have a floor standing Meddings Pillar in North Northamptonshire which you are welcome to use. About 3ft throat and accurate for 60 years old, used it to drill some 1mm dias other day. PM me if you need.
T
