Re: Can't Get my New Machine to work
Hello, I have the same cnc 6090 machine. I completed the mach3 software install today I got the spindle running manually. I ordered the cnc from ebay came from China & there are no directions or manual that it came with. I found someone online with the same machine with the ports & pins settings. I cannot get the x / y / z axis to move at all.
Any help will be greatly appreciated!!!
Thank you
Hi Cncest1925 and welcome to the forum.
You need to give more info some good picture of the inside of the control box and screen shots of your Mach3 settings would help.
These machines may look the same but the internals can be different.
Here's a few things it could be.?
If using a parallel port then mach3 won't work with the 64Bit operating system.
If USB then you'll need manufacturers controller Plug-in for Mach3. Without it, you'll never get it to work.
If using a laptop with a parallel port, not all will work with mach3.
