Re: Step1 stepper drive board from Conqueror Design
john swift
			Hi Dave
going by what looks like two seperate H bridges on your  stepper drivers
I guess instead of the usual L297 + L298 chip set
your stepper drivers use a L297 & two L6203 H bridges
Attachment 21893
  John
 Hi John,  my two H bridges are both L298N coupled with a PIC 16F87 I/P.
If it's the H bridges that need replaced that's no big deal but if it's the PIC won't I be up the creek without a paddle?  What is actually happening is that when I jog the motor in one direction then stop, then jog in the same direction again, the motor doesn't always go in the right direction.
David
		Hi Dave
I'm assuming the board has a  L297 driving the two L298 ICs
they must of connected the two H bridges inside  the L298N in parallel to make a higher current bridge
until CDE are back in business a faulty PIC is a problem
 unless your lucky and the PIC program is not protected so you can copy a working PIC  -  a bit of a long shot I know
for now I would swap the faulty drive with a working drive to prove the driver is the problem and not the control board
changing the switch settings that determines which axis commands the board responds to may be enough instead of physically moving the board – just avoid jogging into an end stop
with a logic probe you monitor the L297 direction pin to see if its the PIC or L297
      John
		Hi John
Thanks again for your help.  I've swapped the faulty drive for the other which is known to be ok and it is working just fine.  If I could just find a CDE X641SC stepper conversion card then I'd be laughing.  I'd be able to fit other drivers.  I'm really struggling with this but I don't want to harass the guy for the drives if he is in hospital!
