thought of fitting a tool length probe? the probes i use repeat at 0.005mm max error on my cnc
Did some assessment on repeatability, found two results...
Took a few random tools, zeroed the Z axis with my Haimer probe and then swapped tools, going to G1 Z0 F100...
T1 0mm
T3 +0.06mm
T8 +0.09mm
T10 +0.08mm
Now, before i dig any further, do those figures seem reasonable for a Bridgeport conversion??
No point looking for issues that are OK or can't be fixed.
Second result - with the Haimer probe fitted, if i repeatedly approach Z0 at F100 I get perfect result of zero every time. If I increase speed to F200 I get an error of +0.03mm, going to F300 or above I get an error of +0.04mm every time.
My thoughts are a following error in the servo setup maybe, overshooting and not correcting possibly?
if your on facebook- these are the probes i use and sell in the uk
https://www.facebook.com/groups/cncm...c_location=ufi
Dave - I had that problem with an IP/M but was able to fix it by using a slightly earlier version of Mach3. Not sure which CSMIO box you are using but have you tried that? Sorry if you've already been down that path! It's solid for me me, though, both for initial setting and using the fixed touchplate for second-operation resetting.
IIRC i am on 062 - gave up messing some time back as i needed to use it, I might revisit this when i get to setting up my powered knee axis.
does probing work correctly as a seperate macro? (not in m6)
As JAZZCNC said, yes it does - i use it on my mini-mill profile for the bridgeport, this has the high-speed spindle and no chance of using tool length offsets at all as the collet is part of the spindle, on this side of the machine i just tick "ignore tool changes" and output one file for each tool number. Its a little tedious but handy if the file is not 100% as they are smaller files.
thats where a tool length probe on the machine comes in real handy. mine is always accurate to under 0.01mm - i hate having to re touch off etc. probably the best thing i ever fitted. (so good i now stock and sell them in the uk)
