Re: 3 Axis servo motor drive
		Can you give a bit more info on the spindle as there are several variations of the 919.
KW ??
Voltage ??
2 pole, 4 pole ??
Pic of the rating plate would help.
johnsattuk
KW ??
Voltage ??
2 pole, 4 pole ??
 Here are the specs:
2 pole
380v or 220v
 24krpm
 model number is ES919A 2P 08,00kw
petesurrey
			Hi am looking to sell my CNC router parts.
I have 3 servo drives with matched motors 1.5kw with 110mm frame size
http://www.xinje.com/en/ProductView....223&SortID=177
They have been running my router for 1 year now and work really well. I have another machine running the same drives but with 130 frame motors and ive had that fro 3 years never had any problems.
I bought this set face to face in China and they are really good quality.  I am open to offer for the full set of three. I do have another as well so in total 4 sets but the 4th set is brand new.
The drives can accept a wide range of inputs including step directions as well ad differential. They can also accept analogue drive as well.
These would be perfect for a Bridgeport mill conversion and be really accurate as they have 2500ppr encoders so closed loop.
Let me know if you are interested.
 Did you end up selling these motors? Im about to pick up a Bridgeport and if these fit will be interested.
		Hi Im am really trying to sell then all as part of the machine but will break if i have to
petesurrey
 Part of which machine? Can you PM me your number? Would be easier to talk through. Thanks.
Chaz
 see my other for sale item its a cnc router
petesurrey
 Ok, but when you posted these for sale there was no mention of it being part of a router. Hence my surprise.
Anyways, cash waiting for motors that I can use on my bridgeport.
petesurrey
 Seeing as your router looks like it might be sold, do you now know if you have servos for sale or not?
You say they are 110 Frame Size (Bridgeport replacements), what shaft sizes are the motors?
		Hi the router is not sold although a few interested parties. I have 1 110 frame motor with 19mm keyed shaft and one 130 frame motor with 22mm keyed shaft.
petesurrey
 Thanks. I need three motors / controllers ideally.
