		Re: Huanyang VFD, how to get Waterpump switching on with UPF/DRV/DCM connectors?
		I use simple Arduino with Ramps controlled by Marlin 2.0. As I mentioned, this is only a MPCNC.
Attachment 25763
chefffe
Attachment 25763
 Ok, so can you have an option where, in your code, you enable a G Code and then enable an output signal? I used Marlin and RAMPS for my 3D printers, so it should be possible.
The same way a heatbed is activated (Relays on the board) you can do here. Enable a relay, switch an external relay that has logic. Ill draw a circuit diagram if it helps ... ?
		Yes sure, this might be an option too. How to do it on a Ramps I am aware.
As I also dont see getting these UPF DCM DRV Ports running like I want, I will rethink this. Thank you for now.
		It should be as simple as this. Your spindle already has some logic to start stop. Tap into that, use a Normally Open switch (add a new relay if needed) to then feed a Normally Open switch triggered by Ramp's output for M8 G Code which then goes to your Coolant Pumps FWD connection. I've Grounded the common side but you need to work out what your VFD wants here.
Attachment 25764
chefffe
			Thanks for your drawing!
 Does it make sense / help?
		I have a 240v pump which is simply wired in parallel with the mains supply to the VFD. This means the pump runs continuously and therefore removes residual heat after each cut, reducing the starting temperature for the next cut. Simple but effective!
Kit
		Yes it makes sense, just dont know what you mean with "flood".
I am still in building phase of the CNC. Meanwhile I drive the pump simply with +24V and DCM triggering a 24V Relay. That means its always on when VFD is on, thats good enough for now. I will later on realize your idea with switching from Ramps with Gcode which is pretty smart.
I build a complete watercooling solution like for PCs with radiator and fan. What I read in the net, the Spindles dont need high flowrates so the little 12V pump should be enough (I hope).
Another question is for Machine Safety. I included a Killswitch which cuts the 230V input power completely. Now I read somewhere that its better to kill just the wires to the spindle, so that the capacitors cannot uncharge via the spindle and making the spindle down time longer? Is that true?
Do you all use RCD Type B for your CNC with VFD?
		Like stepper drivers, the VFD can suffer terminal damage if you connect or disconnect the load when powered. Putting a kill switch in the spindle wiring is only appropriate if you believe there is a real risk of someone getting an electric shock from the spindle itself and don't care if the VFD gets wrecked to save them. If you believe such a risk is real then you shouldn't switch it on in the first place! Safety in this respect has more to do with adequate earthing and proper installation of the wiring. If you're still worried then never touch the powered spindle.
How long the spindle takes to run down to a stop (which is what I think you mean by the spindle 'down time') is not relevant in regard to a personal injury from the spinning tool since by the time you or someone else gets to hit the kill switch it will be too late.
		Ok thank you. I have no experience yet. I just did my first part today (just a little cut on a plate to 230x230) and it worked great. I will keep then my Killswitch as it is but will use a RCD Type B.
Just bought one with pretty insane price ... :-)
