Re: VFD 220v single phase to 380v three phase.
Chaz
Ive got two. Ecogogo, love them. Speak to John Pei, he can provide a quote.
[email protected]
ShenZhen ECOGOO Electrical Co.,Ltd
Phone: 86-139-24624957
Tel: 075528485003
http://www.ecogoo.com.cn
Address: 7F Bldg #E, North Area No. 8
Shangxue Technology Industrial city,
Shenzhen,China
Cheers, Chaz, will see what he can do price wise.
From memory they were around $400 ish. But cant find an invoice from before.
Chaz
$219 all in for 4kw 220 to 380v, but I guess I will have to pay duty, VAT etc. on that when it lands.
Richard
Sounds cheap. You sure its the same unit and from Richard? You may or may not be caught for duty.
Chaz
Quote came direct from John Pei. including shipping. Pretty much exactly the same as other ebay and ali express sellers. If this guy has a good rep, then seems like a good deal.
Just need him to mark it up as a gift! :biggrin:
Richard
Awesome.
Ive bought 2 already - they are good. Ive got a copy of the manual if you need it, John can also supply.
I almost cooked my spindle with one, make sure you check all parameters before trying to run anything.
I run a lathe with 3HP motor off a VFD with voltage-doubler input. It's a bit of a bodge put together some years ago by a company now out of business. The nice bit is an ABB inverter originally designed for 415V/3P in and out. The third party replaced the input 3-phase bridge with a voltage doubler running off 240V/1P in. It works fine, except towards the upper end of its load capacity. My lathe has a mechanical variable-speed arrangement so I leave the VFD on 50Hz but as the VFD load increases with increasing lathe speed, somewhere north of 2K RPM the DC bus ripple voltage trips the fault-detection circuitry and the thing shuts down with an "input phase error" message (or similar - haven't seen it for a while as I tend to keep the speed down). I'm assuming that the bus capacitors are being, in effect, charged at 25Hz and the voltage sag between input pulses becomes too great.
I have looked longingly at these Ecogoo devices, and I wonder if they actually use a switching voltage boost on the input rather than a simple passive doubler. Also wondered about just putting a chunky transformer plus bridge rectifier in front of my existing VFD but haven't stumbled across anything cheap enough to play with yet.
Neale
Ive got 2 at home. One is powering my surface grinder which is not being used at the moment. If you wanted to take a look at the VFD (non destructive of course, let me know).
Neale, Drives Direct are more than willing to provide you with such a setup new, at fantastically wallet emptying prices.
I have looked at building something, but I've never been able to find what VFDs are suitable for online/load switching.
Chaz
There's no fun in that! Attachment 26792
m_c
Attachment 26792
I spoke to Direct Drives. Pricy and when you mention CNC they say 'no sure if that load would work'. So clearly too risk / pricy to experiment.
