Re: Engineer needed West Midlands
Clive S
I can't see anything wrong with the file apart from not having a G21 at the top
T1M6
G17 G21
G0Z20.000
G0X0.000Y0.000S22000M3
G0X0.172 Y2.503 Z6.000
As a workaround could you reduce the DXF file in Vcarve with scale .
It is under "transform objects set size". and reduce it with the %
Okay Great! We will give that ago and if it works use that until the new pendant arrives .We do have Mach 3 on a PC and are also thinking of just using that from now on if the pendants do break, and most people seem to have a PC linked up as it is much easier. Do you know if i would need anything new to connect my pc with Mach 3 on it to my rich auto circuit board. I'm thinking a new circuit board but unsure as to which one ?
Many Thanks Bria
I use ' Discriminator ' for working on Gcode can scale edit very easily
