Nut would appear to be similar apart from the radiused sides, is there room for this . What is the damage to the screw, can't see any in the pics
NO switches are not fail safe, I never use them as limits or in ES positions
Yes there is room for the radiused sides, and the damage was to the plastic part holing the bearings in place. I have tried without success to repack the bearings but even with carefull assembly its got very tight spots.. and the plastic sleeves on the lower part are damaged..
Yes I understand my switches wer'nt fail safe and seems my soft limits didnt help.. As far as Im aware I think one of my sons had been using the machine or maybe from a broken wire on the switch ( not set up diffrently) ? An in my error I didnt check things before I used it (rush job) :(
OK will try to get it machined this weekend
How much ? ect and thanks
Have sent PM
pm sent
Many thanks for the help from johnsattuk saved the day... I am now up and running
amazing help when needed most :)
Already done that now thanks .... all NC
