When I'd stopped fiddling with the spindle, I could let it loose on making a front panel so I could finish the electrics:
The engraving took *forever* - if I went much faster than 50mm/min, the cheap ebay engraving bits would snap. Because I was using the hobby version of Fusion 360 to generate the code, the 'rapids' are limited to the same speed.
http://www.youtube.com/watch?v=15a34Low6pI
Cutting holes was better (caution - loud)
http://www.youtube.com/watch?v=7Z8dKOHa5bo
The end result was this:
https://www.misterg.org.uk/photo/ima...MG_1744.md.jpg
After a bit of de-burring (I should have run a pass around it with a chamfer tool) I was very pleased with the outcome:
https://www.misterg.org.uk/photo/ima...MG_1745.md.jpg
It was a pleasure to be able to build the panel up with everything fitting nicely where it should. (I'd been hoarding that Neutrik USB connector for years, just waiting for something to come up that needed it.)
https://www.misterg.org.uk/photo/ima...MG_1774.md.jpg
Finally, wiring that I'm not ashamed of! (It's not as bad as it looks to work on - the heatsink, with the drivers attached, can be unscrewed and swung out of the way to give access.)
https://www.misterg.org.uk/photo/ima...MG_1786.md.jpg
https://www.misterg.org.uk/photo/ima...MG_1787.md.jpg
It made an actual thing - a mount to hold the SD card reader behind the slot in the panel. (Machined out of a slab of laminate. Thanks to some bug in my CAM, it managed to make a rapid move through the bottom left hand corner and take a chunk out of it. All part of the learning curve...)
https://www.misterg.org.uk/photo/ima...MG_1734.md.jpg
https://www.misterg.org.uk/photo/ima...MG_1735.md.jpg
I decided that the controller looked better with handles on it (I could pretend that I wanted them to protect the switches, etc. but I was just being a tart.)
https://www.misterg.org.uk/photo/ima...MG_1788.md.jpg
As it was a sunny day, I carried it outside to take a photo before I got it too dirty. It weighs about 45kg!
https://www.misterg.org.uk/photo/ima...MG_1858.md.jpg
https://www.misterg.org.uk/photo/ima...MG_1843.md.jpg
X axis travel is 330mm, Y 235mm and Z 114mm. X & Y seem perfectly reliable at 4m / min, Z at 3.6m/min.
I have cut some test pieces on it, but I'm still getting my head around CAM and learning how to use the machine.
I will post some updates to this thread in due course.
