Re: TEP educational CNC machine using TechCAD
martinstokes
Hello! I know it's a long time ago, but I wondered if you could give me any clues about software etc. I recently bought a tep engraver with serial port - it all works fine but I haven't a clue about where to find the software. Any advice gratefully received. Martin.
I have the software.
I can also tell you it is not worth the effort of getting it going. I replaced it all with RAMPS years ago.
http://rollingpast.com/john/techcad/
Please let me know when you have it so I can delete it from the server.
Mjolinor
That was quick thank you so much ! I have downloaded the two zips so you can remove them. I hesitate to ask more questions after you have been so helpful and please excuse my total ignorance but I guess if it's zip I need to run on something like xp (I have xp and later windows, but use mainly linux) ? and what is RAMPS and how do I do that?
Thanks in advance
Martin.
martinstokes
Thanks in advance
Martin.
Presumably you use Nautilus as a file manager if you are a Linux user. That will unzip the files, that is what made the files. I do not use any Windose products other than mice, that is the only thing they do correctly.
Mjolinor
Thanks. Can I run this TEP engraving machine with linuxcnc - it only has serial port on the cnc interface?
martinstokes
You can but not the software that I posted. That runs under Micro$haft only. I can't remember but it may be a DOS programme.
I disassembled the PIC and got LinuxCNC to sort of work but never really took it anywhere because an ON/OFF Z axis is not that useful so I just went all RAMPS with a proper Z axis.
I still have it but have not used it for years because it is just easier to order PCBs form China than it is to do them yourself.
I know this has been a long time. My Clock Club has just been donated one of these engravers. I was wondering if you still had access to the command protocol for the unit such I can write a driver from another CAD. A copy of your LinuxCNC driver would be great if possible.
Thanks Jon
