Re: Setting upstepper drives
croy
Thanks, i am going to finish watching the rugby, then i'll give it another try.
Erm ye Should I really be helping a welsh man after kicking our arse's yesterday. .:joker:
I'm not Welsh, I'm South African. but i did support the Welsh yesterday.
and I'm still grateful for your help.
croy
It's ok I'd much prefer to sit watch that lion on your avitar than rubgy or football.!!. . . . Now motoX or any motosports then thats different story.!
Hi Jazzcnc, going on the figures you worked out would i then be correct in surmising that my potential accuracy for turning can be 0.005mm
Accuracy = Pitch/Steps per
Well there's your problem then.
If 1600 micro steps and 4mm pitch with 20T on motor and 40T screw then try 800 in steps per. So formule (micro steps/pitch) * (screw pulley/motor pulley)
This screw still sounds very rough when it is running. any thoughts on Acceleration and Velocity
croy
What settings are you set to at the minute.? both Acc and velocity please give micro steps drives set to as well.
Mach3 settings
Steps per is 800, velocity 200, acceleration 74
PM542 Controller settings
microstep 8 which is 1600 usetps/rev
4.2 Amps
Have you tried upping both as 200 & 74 is very low.!! When you say they are rough sounding in what way do you mean.? could you take a video.
What Nm size motors.? how are they wired, Bi-polar parallel or series.? Are you absolutely sure you have wired the phase's correct.?
Re: Setting up stepper motor drivers
Hi, it would be really interesting to know how you have fitted the leadscrew please? I have CNC'd my S7 with ordinary screws but accuracy isn't great and I want to fit ballscrews. The Z axis looks a bit of a challenge and it would be good to know how someone else has done it.
Thanks,
John.
John,
The z-axis on a lathe is always a challenge. Have a look at this thread http://www.mycncuk.com/forums/lathe-...onversion.html to see one approach that should work on any lathe...
